Re: farmall 656 hydraulics
Posted by ddg on February 28, 2001 at 17:41:10 from (152.163.205.64):
In Reply to: farmall 656 hydraulics posted by mikek on February 28, 2001 at 16:49:56:
Make sure you use the correct fluid, some of it including some ATF fluids will foam, causing cavitation. In the old Super A, I've had pretty good luck over the years using a straight, non-detergent 20w motor oil
Post A Followup
: Re: Re: farmall 656 hydraulics
