Re: Fluid Change on M Farmall
Posted by Haas on February 28, 2001 at 18:01:13 from (129.37.117.138):
In Reply to: Fluid Change on M Farmall posted by E C Tisdale on February 28, 2001 at 06:45:43:
As stated by Charlie, the M belt pulley does not have a drain. There is a small amount of tranmission fluid in there and it is supplied by splash up from the tranny. To drain it, you have to take the bolts loose that hold the pulley shaft assembly in. These are the bolts behind the flange that the belt pulley mounts on. Once the bolts are out, you can slide out the shaft, bearings and gear as a unit. To change the seal, you have use a press to remove and reinstall the bearings, as they are pressed on. If you don't have a press, take the shaft assembly to a shop that has one. I don't recall if the gear is pressed on or not. When you put it back together, be sure you put back the shims that are between the flange of the shaft assembly and the pulley housing. These shims adjust the gears to the proper mesh. Put them back just like you found them. Also make sure all is absolutely clean regards the mounting surfaces and the shims. One little piece of dirt on the shims or the seating surface and it won't seal and you will have a leak. When you get it back together, refill the belt pulley through the plug on top of the pulley housing with whatever oil you have in the tranny. Capacity is one pint. It is lubricated after the initial fill by splash up from the tranny.
Home
| Forums
Today's Featured Article -
When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
