Re: Leaky brake shaft seals on Farmall C
Posted by Lee K. on March 01, 2001 at 15:33:29 from (205.160.206.85):
In Reply to: Leaky brake shaft seals on Farmall C posted by I see red. on March 01, 2001 at 12:35:37:
It will require removing the top cover and taking the retaining bolt off of the axel that hold the bull gear on. You'll then be able to slide the axel out, leaving the bull gear in the housing. Then lift out the bull gear. After you do this, dissassemble the brake and slide the bull pinion cage out. The seal will be in this cage. You'll need to take the axel and bull gear out or you'll break the bull pinion cage. I seen this happen on an H.
Post A Followup
: Re: Re: Leaky brake shaft seals on Farmall C
