Re: Cub Engine Parts
Posted by Kent on March 02, 2001 at 06:44:26 from (216.248.79.145):
In Reply to: Cub Engine Parts posted by John on March 01, 2001 at 09:54:43:
John,
Usually if these older tractors are in need of an rebuild, machine work will be required to do it right. Since the Cub C60 engine does not have cylinder sleeves, it should be rebored. If your are putting in new bearings, the Crankshaft should be ground.
Parts are readily avilable with no problem. Maybe if you get your parts from the same place you have machine work done, you will get a break on the cost of parts. Shop around prices can vary greatly.
Good Luck,
Kent
Post A Followup
: Re: Re: Cub Engine Parts
