Re: Re: Re: Cub front tires
Posted by George Willer on March 02, 2001 at 16:14:19 from (64.254.131.16):
In Reply to: Re: Re: Cub front tires posted by Paul Ramsey on March 02, 2001 at 15:22:28:
third party image
OK, Paul, If you conducted a poll, which I have not, I think you would find most Cubs plowing would have no fluid, one set of rear weights, and no front weights. That seems to be the most common setup. Your work may be different and you would prefer it set up differently. Let us know how whatever you choose works out for you.
E-bay is fine...but Jim will give you the same tires for the amount of minimum bid and he will make out better if you just call him (I think).
All the tires in the picture are from Tucker Tire.
George
Post A Followup
: Re: Re: Re: Re: Cub front tires
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
