Re: What makes a gas engine run rich
Posted by Redneck on March 02, 2001 at 19:52:29 from (172.133.138.12):
In Reply to: What makes a gas engine run rich posted by Gene on March 02, 2001 at 18:02:00:
Off the wall suggestion. Does the 464 use a ceramic resistor in the ignition circuit? A lot of the older tractors still used 6 volt ignition systems with 12 volt batteries and generators/alternators. Not using the resistor will cause the points and condensor to break down and the plugs to foul rather quickly. It may sound rather far fetched but I've solved more than one plug fouling tractor problem by installing the resistor.
Post A Followup
: Re: Re: What makes a gas engine run rich
