Re: #@$%#% tractor
Posted by The Red on March 03, 2001 at 07:58:43 from (12.75.197.225):
In Reply to: #@$%#% tractor posted by shawn on March 03, 2001 at 07:52:26:
Shawn it sounds like the starter bendix is probably stuck on a ring gear on the flywheel. I don't know if the AV had that problem but Farmall Ms were notorious for that problem as the ring gear became worn. Remove the starter and bench test it. Then see if you can hand crank it with the starter out.
Post A Followup
: Re: Re: #@$%#% tractor
