Re: #@$%#% tractor
Posted by MikeH-Tx on March 03, 2001 at 08:13:55 from (208.2.106.120):
In Reply to: #@$%#% tractor posted by shawn on March 03, 2001 at 07:52:26:
Shawn, check the easy stuff first. Have someone check the voltage at the starter (heavy wire) while you are trying to crank. If you see zero volts, you have a bad starter switch or solenoid, or wiring (trace back toward the battery to find which). If you have full voltage (12?) you have a dead starter. Somewhere in between and Red's guess is a good one (or you have dirty wires to the battery or ground or both).
Post A Followup
: Re: Re: #@$%#% tractor
