Re: Re: tractor won't start
Posted by Red Power Specialist on March 03, 2001 at 18:19:33 from (216.153.68.174):
In Reply to: Re: tractor won't start posted by peterc on March 03, 2001 at 10:21:08:
This is the best advice thus far. With age injectors tend to wear and do not spray out a fine mist as is needed. Even if the glow plugs are good the cylinder temperature has to be warm enough to ignite. To do this you heat it longer. Also get stronger battery.
Post A Followup
: Re: Re: Re: tractor won't start
