Re: Super C front end
Posted by DAve G on March 03, 2001 at 18:44:15 from (158.252.164.152):
In Reply to: Super C front end posted by Brandon on March 03, 2001 at 17:27:57:
If the Super C is the same as a Farmal B here is what you do. I have just done 3 B's. You need to take the 4 bolts off that hold the round assembly up to the front end. Make sure you drain the oil if there is any in there, probably won't be. The assembly should drop down and out. Once the assembly is out you need to take it apart. First, remove the long bolt that holds the whole assembly together (look for nut on bottom).Next is the tricky part - you need to press 2 bearings off in order to get to the big seal buried underneath. To do this you almost need a shop press, which is good to have. I got one for about $120. Be very careful how you press off the bearings so you don't break your round castings (like I did the first time). The top bearing I got underneath the steering gear to press off. The bottom bearing I get off by flipping the assembly upside down and pressing on the bottom casting as close to the center as possible. Good idea to maybe get new bearings along with the seal. To put the bearings back on I heat the bearings and freeze the shaft and they slip right on. It's sure worth doing -- Good Luck.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
