Re: Re: Re: Re: Re: Re: What makes a gas engine run rich
Posted by Paul Vance on March 03, 2001 at 19:19:24 from (64.209.134.135):
In Reply to: Re: Re: Re: Re: Re: What makes a gas engine run rich posted by Gene on March 03, 2001 at 14:41:18:
Gene, on monday, order the proper main jet. On sunday, check your fuel pressure!! If you have WAY! too much pressure gas will leak from the carb while the tractor is running(poorly). If you have just a little too much pressure, fuel will be pushed passed your needle valve and fill up your bowl, the extra gas will be sucked into your intake, causing a slight rich condition(tractor still runs decent). Did you check float level with tractor running? Even if you did, check pressure.
Also, what is your altitude? I live at 7000ft atmosphere psi is avg. 11.6 roughly 20% less o2 than at sea level. Any carboureted engine that is brought here from sea level will run exactly as you describe yours running until you decrease mainjet size by one quarter. This may not apply to you but I see it very often here. (Santa fe NM.) Let us know your results> Paul Vance
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: What makes a gas engine run rich
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
