Re: Re: Re: Re: Re: Re: What makes a gas engine run rich
Posted by dick on March 04, 2001 at 07:53:01 from (63.120.111.98):
In Reply to: Re: Re: Re: Re: Re: What makes a gas engine run rich posted by Gene on March 03, 2001 at 14:41:18:
A fuel leak into the air inlet when the tractor isn't running usually indicates the float level is set too high. Since the float isn't shutting off the fuel intake to the carb. properly, you tend to get too much gas into the engine.
This may be a good bit of your problem. Try setting the float so the level in the bowl is lower.
Good luck, and let us know how you progress. If you still have the strong gas smell, be careful what you're doing so you don't end up with a fire.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: What makes a gas engine run rich
