Re: Re: W-9 no fire
Posted by Andy Martin on March 04, 2001 at 12:30:22 from (38.31.74.43):
In Reply to: Re: W-9 no fire posted by Red power specialist on March 03, 2001 at 18:07:07:
Run the hot wire from the ignition switch to the - connection on the coil. The other connection(+) should go to the distributor. These two connections are each end of a coil of wire in the "coil". To check the coil, hook a spark plug up to the big wire coming from the coil and ground the threaded part of the spark plug. Then ground the wire going to the distributor momentarily. Whe you remove the ground you should see a spark across the plug gap. The coil makes a spark when the current through it is interrupted. Buying a new coil is senseless unless the old one is bad, and they are easy to check. A bad looking wire from the coil to distributor also may be OK but is cheap to replace. If you have put in new points and adjusted them properly, unhook the condenser, even if it is new it may be bad. You will still get a spark with the condenser unhooked. After you get a spark from the main coil wire, you can trace the problem through the rotor and cap if it still exists. Do start with new spark plugs. Good ones go bad sitting sometimes.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
