Re: froze up Farmall C for project
Posted by Haas on March 05, 2001 at 05:50:47 from (129.37.117.63):
In Reply to: froze up Farmall C for project posted by Bryan on March 04, 2001 at 18:11:49:
If the engine is locked up, you should get it CHEAP. Don't pay too much. Should be well under $1000 depending on other condition. Good sheet metal is hard to find and expensive. So if that is good, it's a plus. Rear tires cost $500-$600, so if the tires are flat or dry cracked, you probably will need those. With the engine locked, I'd try to get it for no more than $500, less if it's rough otherwise. Also check to make sure the block is not cracked. Look behind the carburator. That is where they crack out when they freeze up. Good Luck!!
Post A Followup
: Re: Re: froze up Farmall C for project
