Re: How do you check compression on a Super C?
Posted by Bama Binder on March 05, 2001 at 14:46:09 from (206.5.110.200):
In Reply to: How do you check compression on a Super C? posted by Paul on March 05, 2001 at 13:05:56:
Super easy. Get a compression tester. Check when engine is hot. I pull each plug one at a time. Keep the ignition switch off. Choke off, throttle open full. Screw the tester into the plug hole. Hit the starter for 3-5 revolutions looking at the gauge. Interpreting the results is a little more art than science. If the tester jumps right up to about 120 PSI on all cylinders, all is well. Lower compression equals lower horses and more worn engine components. No compression equals stuck valves or busted piston. Weak compression could be worn rings, valves or both. If you squirt oil in the cylinder and the compression goes up, suspect rings. If it stays about the same, suspect valves. Of course there could be other problems like blown head gasket, cracked block or head, burned or bent valves, etc. but these are the basics. Your problem does not seem to me to be compression related though...BB
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
