Re: Help New Restore Here
Posted by Adam Davis on March 06, 2001 at 05:20:50 from (12.29.18.212):
In Reply to: Help New Restore Here posted by carey conlee on March 05, 2001 at 18:12:10:
I found a Farmall F-12 in a woods while I was walking the other night. I went back down to take a look at it last night and it is mostly complete except the seat which is lying about four feet away under some other metal. I walked a little farther and found a pair of fenders which turned out to go on the tractor, and a mounted cultivator. There was also one 3 row pull type plow (JD), two four row John Deere planters (with a double hitch to run them side by side), John Deere disc, drag harrow with wheels, OLD hay rake, a mulcher packer, rotary hoe (pull type), two bottom John Deere pull type plow, and a Model 60 Caterpillar crawler. What is the F-12 worth? How many were made with fenders? How hard is it to get parts for it. Thanks Adam Davis
Post A Followup
: Re: Re: Help New Restore Here
