Re: Re: Farmall H Governor questions
Posted by Catless, OOPS on March 06, 2001 at 16:15:07 from (209.94.173.12):
In Reply to: Re: Farmall H Governor questions posted by Dead H Resusitated on March 06, 2001 at 16:07:25:
If you did, Did you compare the new throttle shaft to the old one, I didn't and had alot of trouble, The new shaft wasn't the same, about 1/8 of a turn difference in the setting that must be made up in the govenor linkage. Just a thought.
Post A Followup
: Re: Re: Re: Farmall H Governor questions
