Re: Re: Re: Re: IH 424
Posted by ltf in nc on March 08, 2001 at 08:11:49 from (206.228.213.106):
In Reply to: Re: Re: Re: IH 424 posted by RB etn on March 08, 2001 at 05:33:02:
If the carb has a pipe plug in the bottom of the fuel bowl remove the plug and observe the amount of fuel that drains after the bowl and lines have had time to empty. You need to have the fuel pump running if it is electric. This has to be a good continuous flow and a stream about 1/8" in
diameter. I doubt if you will have this with the problem you are experiencing.
Post A Followup
: Re: Re: Re: Re: Re: IH 424
