Re: Starting a WD9
Posted by brianh on March 09, 2001 at 05:22:57 from (152.163.194.181):
In Reply to: Starting a WD9 posted by Joe on March 08, 2001 at 21:25:56:
Put the compression release lever in the starting position (this is the position that it latches into against spring tension. It may be either forward or back depending on the linkage). Put the main throttle in the off position. Pull out the choke and hit the starter. Most of these engines don't need much choke unless it is really cold out. Let it run on gas about a minute and then move the main throttle to idle and move the compression release to the opposite extreme, and you will be running on diesel. If it is around 30 degrees you may want to let it run on gas for two to three minutes and if it's around the zero mark you may want to run it for for or five on gas. You will get used to listening for the fast idle RPM on gas. It will slowly increase as the engine warms up, and when it stops increasing is usually when I switch to diesel. When you get ready to shut it off, reverse the above procedure and let it run a few seconds on gas to clean off the spark plugs. Write me direct if you have any other questions. Brian
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
