Re: Starting a WD9
Posted by Haas on March 09, 2001 at 05:42:18 from (129.37.117.202):
In Reply to: Starting a WD9 posted by Joe on March 08, 2001 at 21:25:56:
Brian has pretty much given you the procedure. Although I think you may have to run it a little longer than a minute on gas to get it warm enough. My MD requires 2 or 3 minutes if the engine is cold, even when the weather is relatively warm. If it fails to switch to diesel, likely you did not let it run long enough on gas. When you shut down, be sure to put the compression release lever in the diesel position so the compression release valves can cool on their seats. Failure to do that can result in warped valves and problems.
Post A Followup
: Re: Re: Starting a WD9
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
