Re: poor running tractor
Posted by Bama Binder on March 09, 2001 at 18:15:38 from (63.10.118.225):
In Reply to: poor running tractor posted by ksk on March 09, 2001 at 17:45:39:
Wheeew....100 miles from the arctic circle??? Well...I this situation, I would recommend a 12 volt system because they do start better in the cold. Other than that it is a matter of tuning and timing and good electrical connections. First, go with 0 guage cable from battery to ground and battery to starter. You may want to go with 2 guages larger on all wires to boot. Make sure your starter is in good shape...if it is as important as you say, have it rebuilt. New spark plugs, plug wires, coil, distributor cap, rotor, condensor, and points will help. Make sure your static timing is set to fire at TDC. Set plugs at .025 and points at .017 -.020 .017 there is a lot of slop in the distributor cam. Gas Farmalls / IHs are very good starters if they are properly tuned, but just like everything else, if you have marginal to poor parts, it does not work as well....from the heart of dixie....BB
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
