Re: Re: Re: Re: Re: Farmall A Hydraulics re:rod from side of engine to the back lift
Posted by Haas on March 10, 2001 at 05:16:54 from (129.37.117.6):
In Reply to: Re: Re: Re: Re: Farmall A Hydraulics re:rod from side of engine to the back lift posted by Murray in N.S. on March 09, 2001 at 16:00:43:
Yes, block the wheels that run on the land up to approximately the depth you want to plow. If you have a plow that throws to the right, that would be the left side wheels you want to block up. That puts the tractor in the tilt it will be when the plow side(right side) wheels are running in the furrow. The plow should be close to level side to side when the tractor is tilted like that. Your handle says Murray in N.S. and you say you have snow. Is N.S. Nova Scotia??
Post A Followup
: Re: Re: Re: Re: Re: Re: Farmall A Hydraulics re:rod from side of engine to the back lift
