Re: Serial # and Blocking cast match?
Posted by The Red on March 11, 2001 at 07:22:16 from (12.75.196.126):
In Reply to: Serial # and Blocking cast match? posted by Jim on March 11, 2001 at 07:10:57:
Jim double check that serial number. 23116 would be a 1940. Look above or below the number one spark plug. There will be a serial number stamped on the block.
Post A Followup
: Re: Re: Serial # and Blocking cast match?
