Re: Farmall H - no spark?
Posted by Brian B. on March 11, 2001 at 07:33:24 from (207.177.90.207):
In Reply to: Farmall H - no spark? posted by brent on March 10, 2001 at 16:07:20:
Check your ignition switch. See if you have electricity from your battery to the ignition switch. It should run from there to your coil. If it doesn't you will not get spark to the points. one way is turn on the ignition and take a test light, ground it. Check the terminal going to the coil, if it lights you have power to the coil. next check the side going from the coil to the distributor. If you have power to there you should have spark unless the points are not set right and the spark plug gap is not right. Good luck. B.
Post A Followup
: Re: Re: Farmall H - no spark?
