Re: B PTO guard spacer
Posted by gene b on March 11, 2001 at 20:14:05 from (63.42.174.70):
In Reply to: B PTO guard spacer posted by Dave G on March 11, 2001 at 19:39:06:
manuals sometimes wrong if you take off the pulley drive put a plate over the hole the spacers are used to set gear lash of the belt pulley and also sometimes there is spacers between the trans housing and pto assy to set gear lash hope this clears it up for you
Post A Followup
: Re: Re: B PTO guard spacer
