Re: Is this a Super A or just an A?
Posted by gene b on March 11, 2001 at 20:54:57 from (63.42.174.70):
In Reply to: Is this a Super A or just an A? posted by Ty on March 11, 2001 at 08:31:16:
hole for pump is on the filter side in the area where the front steering assy bolts on there will be a plate over it these holes were cast in all of the blocks from mid 47 even late Bs hade this block also power units used on a bailer used this block replacement blocks had no serial no hope this helps some of the books we buy have some mistakes I can remember new Hs MS and Bs never saw a black seat like some say
Post A Followup
: Re: Re: Is this a Super A or just an A?
