Re: Super A Implements...
Posted by Haas on March 14, 2001 at 13:37:48 from (129.37.117.44):
In Reply to: Super A Implements... posted by Ga-Scott on March 14, 2001 at 11:37:11:
If the stumps are very big, the Super A is not going to do much with them. If they are small and fairly tall and the ground is soft, you might be able to hook a chain to the top of them and pull them over. Otherwise, I think you need to rent a stump grinder or hire a professional that has one. Havn't thought about one of those old disk plows for a long time. We used to have one years ago. Real heavy thing lots of trouble to put it on the tractor. Should plow about any ground you have.
Post A Followup
: Re: Re: Super A Implements...
