Re: Re: H Farmall wet sleeve or dry sleeve?
Posted by Russ on March 14, 2001 at 18:35:56 from (199.199.220.7):
In Reply to: Re: H Farmall wet sleeve or dry sleeve? posted by Les on March 12, 2001 at 02:39:31:
If it were a wet sleeve you would be installing a totally new cylinder so the hole would be gone with the old sleeve, as in the case with a JD. Although I think farmalls are dry sleeves whereas you have a problem.
Post A Followup
: Re: Re: Re: H Farmall wet sleeve or dry sleeve?
