Re: M Hyd
Posted by Roger on March 14, 2001 at 20:29:23 from (209.224.35.87):
In Reply to: M Hyd posted by Ed Read on March 14, 2001 at 05:44:44:
Ed, I calculated the flow rate one time for the hydraulic system. I timed how long it took for a 4 inch cylinder to go a certain distance and then used that to calculate the gallons per minute. I calculated a rate of 11 gallons per minute. I guess you are a real Farmall nurd when you do things like that. Roger
Post A Followup
: Re: Re: M Hyd
