Re: Tires Rims
Posted by Haas on March 15, 2001 at 13:21:27 from (129.37.117.79):
In Reply to: Tires Rims posted by Bama Red on March 15, 2001 at 07:40:43:
You need to check the size of your rims. They are probably 11 X 38. That is what most Ms have. Since others post that the 15.5 is the same as the old 13x38. If you have at least 11 inch rims, I think the tires will work. If you have 10 inch rims, which is entirely possible on a 41 model, I think tires that big might not work too well.
Post A Followup
: Re: Re: Tires Rims
