Re: Need solinoid for starter switch?
Posted by big fred on March 16, 2001 at 21:09:39 from (208.51.245.45):
In Reply to: Need solinoid for starter switch? posted by Nick on March 16, 2001 at 18:10:36:
As Dan said, the Ford unit should work fine. For some reason, Ford seems to mount theirs off the starter and call it a "relay" while GM mounts it on the starter and calls it a "solenoid". If you are running a 6V system, the Ford 6V relay also has a pushbutton on one end that can be used as a remote starter switch. The 12V versions I have seen don't have this.
Post A Followup
: Re: Re: Need solinoid for starter switch?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
