Re: Re: Re: Is it ok to replace manifold studs with bolts?
Posted by Tom H on March 17, 2001 at 17:17:31 from (63.93.2.198):
In Reply to: Re: Re: Is it ok to replace manifold studs with bolts? posted by Chicken George on March 16, 2001 at 11:58:23:
The reason the allen bolts broke is because most of them are a grade 8 or harder which makes them brittle under heat. Another thing to remember is that stronger is not always better. A grade 5 bolt will stretch where a grade 8 will break.
Another reason for useing studs is that they only have a certain length of threads on them so you don't screw them in to far and crack a head.
.01 cents worth
Tom
Post A Followup
: Re: Re: Re: Re: Is it ok to replace manifold studs with bolts?
