Re: Re: Wide front position
Posted by Dick Davis on March 18, 2001 at 02:32:19 from (152.163.204.79):
In Reply to: Re: Wide front position posted by Haas on March 17, 2001 at 18:25:17:
Yup, ya got to make the holes! First WFE I mounted didn't come with the adapter plate so I had to mount it in the long wheel base position and that required drilling two 1/2" holes in the bottom of the frame rails. Actually I think the short wheel base holes had to be drilled when the wfe was installed. Th long postion does makes the tractor look different, I like it. D-2
Post A Followup
: Re: Re: Re: Wide front position
