Farmall Tractors Discussion Board
farmal 656 transmission slips out of Gear
Posted by Greg S. on February 03, 1999 at 20:11:30:
I have a 656 with high/low range, the problem is that when in low range it slips out of gear going down a small sloped hill or if you hit a bump in the field. Also say if your plowing up the fields it will sometimes come out of gear, but will go if you put it in high range. I removed the transmission, but not sure what can cause this. The clutch and pressure plate look ok,possible to be in the torque ampifier?? Any ideas, can use the help, I do have a repair manuel.
Post a Followup
: Re: farmal 656 transmission slips out of Gear
