Re: Moving Cottonpicker
Posted by Cottonpickin Jimbo on March 19, 2001 at 19:17:52 from (63.61.96.187):
In Reply to: Moving Cottonpicker posted by Tom on March 19, 2001 at 08:21:24:
Before we went to 4-rows most dealers had a small two wheel caddy that went under the rear tailwheel. You could secure the tailwheel to the caddy and disconnect the input shafts from the final drives on the drive tires(a must if towing over twenty MPH)and tow with a pick-up. I pulled a 422 about 70 miles in about 4 hours that away. 30 MPH would be pushin it I believe.
Post A Followup
: Re: Re: Moving Cottonpicker
