Re: Rod Knocking in my M
Posted by Charlie on March 20, 2001 at 05:59:55 from (209.130.139.113):
In Reply to: Rod Knocking in my M posted by jiM on March 20, 2001 at 05:28:45:
I had a knocking noise in my M one time and it turned out to be bent push rods for the valves. They were noticably bent when I removed them. I put in new ones and tossed the bent ones. If thats not the problem you could try removing the oil pan and see if you can find something with the pistons. I had a knock in my H once that I ignored and one day it put a piston through the block. I'd definitly find the problem and fix it before something bad happens.
Post A Followup
: Re: Re: Rod Knocking in my M
