Re: farmal H with MW clutch
Posted by john d on March 20, 2001 at 18:46:26 from (152.163.204.208):
In Reply to: farmal H with MW clutch posted by Hank Hayne on March 20, 2001 at 04:24:18:
M&W made these for H and M tractors. They provide a "sort-of" live PTO, in that you can use the hand clutch to stop the forward motion of the tractor while leaving the pto engaged. This is accomplished by releasing the left side of the differential shaft and allowing it to spin freely while the pto still runs. If you get this thing fixed, DO NOT attempt to shift gears while the pto is running!
I don't think you can run the tractor successfully until you either fix or remove this unit. If you do a search of the archives on this board, I think you can find some pictures from the manual as well as info about replacing the clutch disks.
Post A Followup
: Re: Re: farmal H with MW clutch
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
