Re: 12 Volt: Rewind Generator or Alternator???
Posted by stevie_alc on March 21, 2001 at 20:09:28 from (216.170.58.10):
In Reply to: 12 Volt: Rewind Generator or Alternator??? posted by Jake on March 21, 2001 at 16:49:42:
Have an M on 12 volt. Went with new plugs,12 volt coil and electronic igniter to replace points and condenser. Mabe the plugs wont foul as much. With todays gasoline you need a good hot spark. I should add I used an alternator.
Post A Followup
: Re: Re: 12 Volt: Rewind Generator or Alternator???
