Re: M Tires
Posted by Haas on March 22, 2001 at 14:52:07 from (129.37.117.105):
In Reply to: M Tires posted by Dave K on March 22, 2001 at 08:55:48:
Since you have two different tires, check the rims to make sure they are the same. Most Ms have 11X38 rims and 13.6 x38 tires. You only need wider tires if you are into heavy pulling. The M will pull a lot with the 13.6 tires, especially if you have solution in them. Normal pressure for the rear tires would be 12 to 15 psi and around 30 for the front.
Post A Followup
: Re: Re: M Tires
