Re: Farmall A lubricant
Posted by Haas on March 22, 2001 at 19:23:40 from (129.37.117.64):
In Reply to: Farmall A lubricant posted by steve on March 22, 2001 at 18:44:59:
I just changed the tranny oil in my C that I got last fall. The oil in it looked cream colored. I think it is because it is a water emulsion. Apparently the additives in the oil are made to hold the water and not let it separate. Consequence of never running the thing enough to get it hot enough to cause the water to leave. AS to the check points. PTO and transmission are together so only worry about the transmission. The place to check level is on the let hand side near the front of the transmission. There is a small pipe plug that is behind one of the pedal rods. I think it is the brake rod for the left brake. You'll probably have to take the rod loose to get to the plug. Fill the tranny until oil comes out that hole. As to the final drives, fill them up to the bottom of the fill hole that is on the inside of each final drive casting around the level of the drawbar bolts. There is no drain on the final drives. You have to remove the pan. Go get new gaskets before you do that. Use 90 weight gear oil in the transmission and final drive. Or you can use HyTran (Tractor Fluid) although some think it is too thin for the older tractors. I put HyTran in my MD and used HyTran in the 140 I used to have. I put 90W in my C.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
