Farmall Tractors Discussion Board
Re: When to change Hydraulic fluid
Posted by Mey on February 04, 1999 at 08:08:40:
In Reply to: When to change Hydraulic fluid posted by Scott on February 04, 1999 at 07:41:42:
Scott,
You've caught at a good point. That indicates moisture is getting in the system. Change the fluid now, there are a few probabilitys on why moisture is getting to the unit. Are there any leaks any where?? Mabie a worn o-ring on the piston.
Hope this helps a bit,
Mey
Post a Followup
: Re: Re: When to change Hydraulic fluid
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
