Re: H hyd. lift.
Posted by Haas on March 24, 2001 at 12:36:42 from (129.37.117.123):
In Reply to: H hyd. lift. posted by Whiskers on March 24, 2001 at 09:23:01:
You can put a one way restrictor in the hydraulic line. It will not restrict the flow to the cylinder, but the flow rate back out of the cylinder will be adjustable. You can get one from Northern Tool. I suppose a place like Tractor Supply might have them too. It's real hard to let the lift all down slow with out some kind or restricter. Another option is to get a spool valve that will allow you to control the cylinder as a two way cylinder instead of one way. That is going to be a lot more expensive and will require quite a bit of piping and hose. You have to run the return from the spool valve back to the fill pipe on the lift all. In addition, there would be a hose from the liftall outlet to the spool valve and two hoses from the spool valve, one to each end of the cylinder. With the spool valve system, you have to lock the lift all in the lift position when ever you are using the spool valve.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
