Re: long V-belt
Posted by haas on March 25, 2001 at 15:07:06 from (129.37.117.98):
In Reply to: long V-belt posted by Rex on March 25, 2001 at 14:19:07:
What kind of mower does it fit??? Is it a Woods Belly mower. If so, look for a Woods equipment dealer. He probably has the belt in stock or can get it fairly quickly. Be aware the Woods mower belts are special high tension belts designed for shock loads so where ever you get the belt, the supplier needs to be aware of the use. A regular vee belt will not last very long on a woods mower. If you have the old belt, you might also look for a belt supply outfit in your town.
Post A Followup
: Re: Re: long V-belt
