Re: H hyd. lift.
Posted by john d on March 26, 2001 at 07:38:20 from (206.141.74.34):
In Reply to: H hyd. lift. posted by Whiskers on March 24, 2001 at 09:23:01:
I'm gonna have to agree with both Haas and Red. The liftall unit SHOULD allow you to lower the 3pt with some degree of control. On mine, I found I could carefully handle the lever and get results, even with a heavy load. I did install an adjustable restrictor valve in the line, however, mostly as a safety and conveniece measure. Mine came from Northern, and it works well.
Post A Followup
: Re: Re: H hyd. lift.
