Re: F-20 headbolt torque
Posted by Bruce on March 26, 2001 at 18:37:18 from (216.179.14.55):
In Reply to: F-20 headbolt torque posted by Mike Schwartz on March 25, 2001 at 19:53:12:
I've had a lot of trial and error experience on this one, so I'll tell you what happened. First,there are no torque values for F20's anywhere, as far as I know. Second, the repro Victor gaskets are much!! thinner than the original head gaskets (which were largely made of asbestos). Third, is your head surface true and smooth? It needs to be, if you want a good seal.
Fourth, I started with 85 lbs. of torque using
proper bolt sequencing, and did not get a good seal. Finally ended up torquing hot at 110 lbs.
and haven't had any trouble since. I'm pretty convinced that these thin replacement gaskets just
don't have enough give in them to get a tight seal. That makes it pretty important that you
have the head surface really smooth. Good luck.
Email me if you want the head bolt sequence.
Post A Followup
: Re: Re: F-20 headbolt torque
