Re: Re: Magnetos vs. battery ignition?
Posted by Bill {Antique Acres} on March 26, 2001 at 20:08:42 from (63.162.254.39):
In Reply to: Re: Magnetos vs. battery ignition? posted by Chris Auer on March 26, 2001 at 19:05:51:
If you are only running it 50 hours or so, I would say your point problem is due to the contacts corroding. On the other hand Points, condensor, and rotor only run around $10.00 for that mag. If you only replace them every 2 years, then you could pay off the new electronic ignition in about 25 years. Plus probably another 15-20 for the distributor. Not saying the electronic ignition isn't nice, but I would only put one on a tractor that really gets regular use. Bill {Antique Acres}
Post A Followup
: Re: Re: Re: Magnetos vs. battery ignition?
