Re: Change tranny fluid
Posted by Rick on March 27, 2001 at 19:14:16 from (205.188.198.23):
In Reply to: Change tranny fluid posted by Martin Kellner on March 27, 2001 at 13:29:22:
I like to put a couple quarts of ATF in the transmission and take it for a drive in road gear. Been know to disappear for an hour or more on these drives. Bring her home and pull the plugs and let drain overnight. Then I go with the kerosene. I use real clean drain pans for the kerosene because usually, the kerosene will still be clean enough to use in the space heater. ATF has a high detergent content and running the tractor in road gear insures that the transmission and rear end walls and covers will get a good bath. Good Luck
Post A Followup
: Re: Re: Change tranny fluid
