You can do as Scotty says, but only if you need to. If you are installing a new, or old, (better new) pressure plate, just measure the height of the levers from the housing surface (with the clutch installed on the flywheel), and adjust the one that is off to the same height as the other two, not likely all three will be off on a new plate. The finger to release bearing clearance is supposed to be set with the clutch linkage, not the fingers. Mess with the fingers only if you cannot get the clutch to release properly -- and it probably won't do any good then (been there, tried that) The main thing is to make sure the fingers are at the same height from the pressure plate, or have exactly the same clearance from the release bearing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
