Re: IH plows
Posted by the tractor vet on March 30, 2001 at 19:34:23 from (216.196.13.108):
In Reply to: IH plows posted by Greg H. on March 30, 2001 at 10:22:25:
You can make a four bottom out of a five bottom , I have done this many times, the IH plow is the easiest to cut down they are all built on a three bottom base just remove the last bottom and move the tail wheel up to the next set of holes and rebolt it no drilling required then move the tail wheel pivot arm up to the next set of hole and rebolt it then shorten the coupling pole and you are done takes about two hours for the first time .
Post A Followup
: Re: Re: IH plows
