Re: M govener spring
Posted by Bob M on March 31, 2001 at 06:58:20 from (66.66.72.246):
In Reply to: M govener spring posted by sprout on March 31, 2001 at 04:55:44:
Hey Sprout - Before you tear into the governor here's a couple things to check: 1 - Make sure the carb throttle linkage is not binding. Loosen both screws that hold the throttle cross shaft tube to the governer bellcrank housing. Wiggle the tube a bit then retighten the screws. You can also remove the slanted cover from the bellcrank housing, and with the throttle lever set to idle try rotating the throttle shaft. It should move freely with no evidence of binding or sticking. 2 - Is the carb idle mixture adjustment set wrong? With the motor fully warmed up and idling, very slowly pull the choke rod out. If you find a spot where the motor quits loping, your idle jet is set too lean. Good luck!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
